18 vdc 20 amp output adapter?
Postby Paulie151 » Wed Apr 04, 2012 6:51 am
Can anyone tell me where to find an 18 vdc, 20 amp transformer, adapter or power supply? Preferably an inexpensive one. The amp output does not have to be 20 amps, but I need it to be at least 10-15 amps, but no more than 25.
If not readily available, can someone please tell me how to make one?
Paulie151
Re: 18 vdc 20 amp output adapter?
Postby Major_Problem » Fri Apr 13, 2012 8:54 am
When you put a couple of computer power supplies in series, you've got a very cheap supply with enough power. Three supplies with 5 volts and one with 3 volts. An other way is to modify four 5 volt supplies but that needs some study.
The supplies are normally available at garbage dumps etc, so for free :) So when you destroy one, no probs.
Grretz,
Wim
Major_Problem
$31.24
Power Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82 pictureMOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel IRF Series
$47.97
MOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel IRF Series picture840 PCS PNP NPN Power Transistor Assortment Kit 24 Types Electronic Component
$24.48
840 PCS PNP NPN Power Transistor Assortment Kit 24 Types Electronic Component picture
