Giant LED strobe
Giant LED strobe
Postby miitro » Wed Apr 18, 2012 4:00 pm
I'm new here I really like what you are doing here it's great (:
I would like some help in developing a circuit.
I want to make a circuit to strobe a white led board.
This board has 64 cells wired in parallel, on each cell is 12 LED in series. They total to 768 LEDs and 150w
The board is powered by one 24v DC source. There is sufficient power output to power a circuit to make the LEDs strobe.
I would like an on/off switch and a potentiometer to vary the flash speed from 10 flashes/second to about 40 flashes/second.
Would the LEDs support such a use?
How would I go about making such a circuit, your help would be much appreciated.
Thanks in advance Henry.
miitro
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063)
$80.00
ASCO HV2647003 Solenoid Valve 3/8” 24 VDC (Box 26-063) pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY
$399.00
NEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY  picture
