phone charging help please
Postby mitchdublin » Thu Apr 19, 2012 11:35 pm
Hi, Im building a multiple mobile phone charging station using usb hubs. Most phones are 5v and draw 500ma to charge.
If i want to charge 500 phones at the same time, how much input would i need. We use 240v with 32 amps coming into office.
Would that mean that i could only charge 64 phones? or am i missing something here. I know the office supply can run lights, pcs, air con, heaters, microwaves all at the same time. I must be calculating the draw of a mobile incorrectly, i didnt think a mobile charger used much power?
Any help really appreciated.
mitchdublin
Re: phone charging help please
Postby I_Daniel » Fri Apr 20, 2012 12:02 pm
One phone at 500 milli-Amps x 5 volt is 2.5 watt.
Your input/available wattage is 240V x 32A = 7680 Watt
From this you could do some further calculations. i.e 2.5W x 500 = 1250 Watt.
Remember to take the transformer losses into account and add about 20% to 25% to the 1250 Watt.
The point you are missing is that it is the available input wattage (or K V A) and the output wattage used to charge the phones.
Think of a desktop computer with a 300 Watt power supply. The fuse is usually 2 amps and the 5 V output is rated at about 35 amp and the 12 Volt output at about 12 Amps.
Unless it is in a factory I doubt whether there is ever any need for 500 chargers.
Another thing to remember is if charged from a PC via the USB then the amps available is about 80 Milli-amps per USB Port. But check the specifications of the USB Port.
Postby mitchdublin » Fri Apr 20, 2012 12:41 pm
Thanks for your help, im trying to build a mobile charging unit for outdoor festivals. Most phones will work on the 24 usb hubs that i have. only the iphone needs a computer connected to hub to power it. Trying to sort that now.
mitchdublin
4/0 AWG GAUGE Copper Battery Cable Power Wire Car, Inverter, RV, Solar
$98.95
4/0 AWG GAUGE Copper Battery Cable Power Wire Car,  Inverter, RV, Solar  pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
$39.97
Hoymiles HM-300N Grid Support Utility Interactive Inverter Microinverter pictureATV320U22M2C IN STOCK inverter ship by UPS/ US Free TAX
$302.76
ATV320U22M2C  IN STOCK inverter ship by UPS/ US Free TAX picture
