How to made high ampere motor driver..?
Postby JangKang » Thu May 03, 2012 9:03 am
Anyone can help me, how to make the high ampere of motor driver...?
what components that should I'm use...?
JangKang
Re: How to made high ampere motor driver..?
Postby pebe » Thu May 03, 2012 10:03 am
AC or DC supply? What is the voltage and current the driver is required to switch?
Postby JangKang » Thu May 03, 2012 10:20 am
it is for DC and trigger from PIC16877A......
i already try basic relay motor driver, from its burning....coz my motor use high ampere.
thank for ur response sir.
JangKang
Postby pebe » Thu May 03, 2012 12:31 pm
To be driven from a PIC, you need logic level power FETs.
For high current types, have a look at these:
http://www.digikey.com/us/en/ph/Interna ... 20Products
Postby JangKang » Fri May 04, 2012 10:12 am
can u help me sir, to combine this all circuit...?
and check it.... here i attch u some motor driver + mosfet...
from other blog that i found.
here : http://www.e-shore.com.my/homepage/all- ... motor.html
JangKang
Postby pebe » Fri May 04, 2012 3:40 pm
The other thread on this board about reverse switching a motor, and to which you posted a question, dealt with using a relay to switch the motor. So I thought you wanted solid state switching instead of a relay.
If you want to use a relay then simply switch it with a transistor driven from your PIC. There are circuits for that in the link you provided. The circuit in Part 1 should be OK.
Postby Major_Problem » Sun May 06, 2012 9:05 pm
Main concern is to keep current flowing while switching the motor off. You have to place a high speed flywheel-diode across the DC-motor. Current through the diode is the same as which flows through the motor. When you would use a low-speed diode, very high peak-voltages will occur. Thats why your relay contacts are burning. Also place a large capacitor as buffer for the current. Keep all leads as short as possible between relay (or mosfet), diode and capacitor.
If you need a circuit, please post back.
Greets,
Wim
Major_Problem
Postby JangKang » Mon May 07, 2012 2:11 am
yea, i need circuit... Thank for ur's all respond sir.
JangKang
Bose PowerMatch PM4500 is a 2000-Watt configurable professional power amplifier
$2200.00
Bose PowerMatch PM4500 is a 2000-Watt configurable professional power amplifier pictureNEW In Box Fireye D-Series Amplifier Ultraviolet Amp 72DUV1 Made in USA*
$200.99
NEW In Box Fireye D-Series Amplifier Ultraviolet Amp 72DUV1 Made in USA* pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER picture
