Hi There
I am trying to switch an LCD display from a micro port .
My circuit works fine without a load .
When I use LCD as a load the transistor does not turn off and instead 0vdc
I get 3.75VDC.
I tried 10K resistor across the load but same problem
I would appreciate if someone could explain me the reason for the problem and suitable solution .
If bipolar is not a suitable solution I will consider using N MOSFET
Many thanks
Nissim
