H-BRIDGE IS NOT WOKING PROPERLY
Postby vinodgambhir53 » Mon May 07, 2012 5:22 am
SCHEMATIC DIAGRAM
[/attachment]4 MOSFET IRFP450
2 COUPLE INDUCTOR
2 IR2110
SMPS FREQENCY (PWM) 40KHZ
PROBLEM:- WHEN SUPPLY 0F 24V 12 AMP APPLIED TO H BRIDGE THEN "HO " OF IR2110 BURN...PLZ TELL ME IF ANY FAULT IN CIRCUITRY OR ANY OTHER THING THAT CAN BE HELPFUL
vinodgambhir53
Re: H-BRIDGE IS NOT WOKING PROPERLY
Postby Major_Problem » Thu May 24, 2012 6:03 pm
High-side driver for DC motor controller
Eindtrap driver.png (29.72 KiB) Viewed 4923 times
[/attachment]You are probably lacking a couple capacitors and high speed, low voltage drop diodes to protect the outputs from spikes due to the inductances on the electronic board.
Use fly-wheel diodes from output to clamp the voltage to VB. Across VB and VS a ceramic and elctrolytic capacitor.
I used the IR2125S and IR2121S for my H-Bridges. They have current control an error-feedback for processor control. So you could best ignore the CS input circuit in your case.
I also had to clamp the secondary ground to the primary with a high speed diode as well. I'm not shure about your IR2112.
Major_Problem
General Radio Company Co. 1153-AP Digital Frequency Meter Numerik Indicator
$999.99
General Radio Company Co. 1153-AP Digital Frequency Meter Numerik Indicator pictureRadio Frequency Gripmeter Pratt Burnerd Gripmeter 1009-07300 R F Gripmeter
$300.00
$498.00
5 in 1 Body Sculpting Machine Professional Salon Spa Radio Frequency For Home picture0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW
$76.87
0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW picture
