op amp amplifier circuit help
Postby sri.jnana » Sat Jun 23, 2012 9:27 am
hello!!
am doing a project on amplifier circuits.. so please let me know the op-amp circuit(op amp number,resistors and any more to be used) to be used to get an output which is sufficient to a relay circuit.
please also mention the minimum voltage required to get a relay circuit operated to connect to a 12 volts battery.
sri.jnana
Re: op amp amplifier circuit help
Postby pebe » Sun Jun 24, 2012 3:19 pm
Your question is far too vague.
Why would you want an op-amp to turn on a relay? Why not just switch the relay?
Then again, why would you need a relay? Why not switch the appliance (whatever it is) with a simple switch.
You need to fill in much more detail about the overall concept.
Postby sri.jnana » Sun Jun 24, 2012 7:19 pm
we are doing a project and in our project i got a ir sensed output about 1 volt. but i need a 12v battery to be connected if the sensor is sensed. that means we need to connect a 12v battery to the load if the output from the sensor is 1v.
for this purpose if i want to use a relay i need a minimum of 6v. for this purpose i need a 1 to 6v amplifier circuit...
please provide me any circuit using an op-amp(741) to amplify 1 to 6 volts..
thanks in advance
sri.jnana
Postby pebe » Wed Jun 27, 2012 9:02 am
If you need the 6V because you are going to use a relay with a 6V coil, why not use a transistor to drive it - if the IR sensor can provide enough current?
If you have a 12V battery then why not use a 12V coil relay? It would take less current.
$31.24
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 pictureTO-92 Assortment NPN PNP DIY kit 15 value 600pcs Transistor
$14.40
