Need Help with a Timer LED circuit
Postby donnytella » Sun Aug 05, 2012 1:03 pm
Hi everyone, I am new to this forum and fairly new to electronics too. can anyone help me with a circuit I need to design and build?
I need to build a timer circuit that will switch on a Red and then a Green LED alternately every (30 - 40 seconds, variable would be even better). Also, if possible, I would like to sound a buzzer (1-2 secs) every time the green LED is lit. This cycle would continue until the circuit is switched off... Oh and yes I need an ON/OFF switch to the circuit.
can anyone help with an exiting circuit design? I am quite new to this though, so nothing too complicated please.
Thanks guys
Terry
donnytella
$31.24
TO-92 Assortment NPN PNP DIY kit 15 value 600pcs Transistor pictureMOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel RoHS
$44.97
MOSFET Transistor Assortment Kit 50 Pcs 10 Values N-Channel P-Channel RoHS picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$6.35
3pcs 2N3055 / TRANSISTOR / CROSSES TO ECG130,NTE130 / TO3 picture
