FM Transmitter question
Postby jdouglasusn » Wed Aug 08, 2012 7:08 am
How exactly do we test this circuit to see if it's working properly?
Do I plug in a audio device (let's say my MP3 player) to the audio input.
Set my radio for like 103MHz, and adjust R1 until i hear something, or am I way off track?
FM Transmitter.jpg (26.95 KiB) Viewed 6585 times
jdouglasusn
Re: FM Transmitter question
Postby pebe » Wed Aug 08, 2012 9:26 am
Yes, that would seem to be the obvious thing to do.
Postby rameshrai » Mon Oct 15, 2012 11:20 am
you can use EDAs to stimulate and see the output if it is working and obviously later on you need to verify practically....I do my simulation on ADS, done such [url=http://blog.ektel.com.np/2012/10/rf-mixer-design-basics-and-image-reject-mixer/]RF mixers[/url] and modulation such as [url=http://blog.ektel.com.np/2012/09/design-of-dqpsk-modulator-demodulator-rf-front-end/]dqpsk modulators[/url]...check might help you
rameshrai
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureC-Can HFRII48/60M Industrial Battery Charger Rectifier Power Supply 48V 60A,WORK
$289.99
C-Can HFRII48/60M Industrial Battery Charger Rectifier Power Supply 48V 60A,WORK pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture
