help,12 v circuit board with computer controlled switches
Postby Baxidur » Sat Aug 11, 2012 4:59 am
Hi
First off i'm new to this so please try to to flame me to badly for any ignorance of electronics on my part.
I'm trying to build a circuit that will fit in a 5 cm x 5 cm x 3 cm box, it will have a 12 volt powered usb connection and six individual wires leaving the box, each of the six wires leaving has the following requirements :-
1: the ability to turn on and off a 12 volt + power supply from a computer with binary code down the wire through a device then to a common earth.
2: the ability to register the voltage passing through in 1% increments of the 12 v's from 0-100% and send this information via binary code down the usb output. (i was thinking adc, but there may be better ways.)
Also the 6 wires need to be individually configurable on/off seperate readings and individually noticable 1-6 for the computer.
A way to individually fuse or resetable fuse the system would also be a bonus
Thanks in advance for any help and i'll try to check back here daily to answer any extra questions
Mark Nutley
Baxidur
E Two Syneron Candela Sublime Sublative Machine, radio frequency
$1999.00
E Two Syneron Candela Sublime Sublative Machine, radio frequency pictureRadio Frequency Gripmeter Pratt Burnerd Gripmeter 1009-07300 R F Gripmeter
$300.00
$498.00
5 in 1 Body Sculpting Machine Professional Salon Spa Radio Frequency For Home picture2023 BTL EmFace Radio Frequency With lot's of Consumables and cards
$29000.00
2023 BTL EmFace Radio Frequency  With lot's of Consumables and cards picture
