help regarding using Arduino to drive laser device
Postby rochasrochas » Sat Sep 01, 2012 2:27 pm
Hi, I need to use Arduino uno as an interface to drive laser operation from a programable power source. The power source has 0V (as +) and -28V (as -). The idea is using LM7805 to convert the voltage down to 5V to trigger arduino.
The wiring design is like what shown in the diagram photo. When I tested this system with 12V battery, it seems works fine. But when I connected this system to the real external 0V/-28V power source, it messed up the circuit of external power source and blew the power source I think. The uno is still fine afterward though. This is only happened when uno is connected to the laser (the device that uno will drive) when 0V/-28V power source is used, but not when the uno is tested alone with external power source. Any thought for what might be the cause??
wiring diagram.jpg (53.16 KiB) Viewed 4181 times
rochasrochas
Re: help regarding using Arduino to drive laser device
Postby Landtronic » Thu Sep 06, 2012 12:48 pm
Test if 7805 is OK.
Try this schematic
Landtronic
$29.99
Hydraulic Leveling and Slide Out Replacement Motor and Polarity Solenoid picturePC218 Phase Polarity Tester Checker Detector Audio Speaker Mic Sound Testing
$175.80
PC218 Phase Polarity Tester Checker Detector Audio Speaker Mic Sound Testing pictureCustom Dual Channel DC Test Control Box AC Powered Tested Working
