Current Running into a Dependent Current Source
Postby jldalton17 » Wed Sep 12, 2012 12:50 am
Hi
I am having trouble determining what my equation for a current should be and was looking for some help.
Its a single node pair circuit : ( Attached )
As you can see below the circuit i have expressions for i (sub) a & i (sub) c, but a very wrong expression for i (sub) b. I'm looking for some help with determining i (sub) b for a KCL.
Jon
jldalton17
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureNew Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display
$123.99
New Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
