Calculation Method.
Calculation Method.
Postby navinchandra » Wed Sep 26, 2012 2:45 am
I have made LED panels in which 4 LEDs are in series and such 45 series are placed in parallel.
I want to operate it with [u][b]CONSTANT CURRENT[/b][/u] LED Driver. There are many constant current drivers are available off the self. To select suitable driver I need to supply voltage and current of entire panel. [b]how to calculate the same[/b]. As per specification of the LEDs used, its voltage[i][b] Vf[/b][/i]=3.2v and [i][b]If[/b][/i] is 20mA. LEDs I have used are SMD. If need be, I can send schematic diagram, for which please grant permission.
Thanks.
NAM
72 yr old, retired person and electronic hobbiest.
navinchandra
$5.99
$6.47
Cavitron power potentiometer for Gen 131, 132, 136, 137 pictureClarostat RA30 LASB 100 OHM Wirewound Industrial POT
$14.95
