linear capacitor charge circuit
Postby waltsar » Sat Nov 10, 2012 5:35 pm
Hi, this is my first post. I am trying to find a simple way to build a circuit that will charge a capacitor linearly ( as opposed to exponentially).
I'm using a 12VDC unfiltered power supply (this is necessary for other reasons). This circuit will provide the reference voltage for an LM339 comparitor.
Thank you,
Walt
waltsar
Re: linear capacitor charge circuit
Postby pebe » Mon Nov 12, 2012 3:08 pm
You could configure a transistor as a constant current generator. Do you want a circuit?
$25.00
$88.88
$180.00
$300.00
