Help connecting potentiometer
Postby shubham123 » Tue Nov 13, 2012 11:56 am
I am making a project I am not really sure how to connect the potentiometer.Main aim is to vary the voltage.
I connected the -ve end of the battery to one of the ends of the pot, +ve end of the battery to the other end of the pot,-ve of multimeter to -ve of battery, +ve of mutimeter to the middle point of the pot and I got a perfect reading.
But doing the same in the circuit but it did not work.
Have to connect the pot with Vbb in the given diagram.
shubham123
Re: Help connecting potentiometer
Postby pebe » Tue Nov 13, 2012 12:31 pm
This is all to do with the posting on your previous thread, and so you should have continued in that thread - not started a new one.
However, you won't get much base current from a 1.5V source through a 200K resistor. So wire the pot as you suggested but connect a 220ohm resistor between its slider and the base of the transistor. You will then be able to get up to 5mA base current.
Then [u]measure the base voltage directly on the base.[/u]
Postby shubham123 » Wed Nov 14, 2012 11:30 am
Sorry for starting a new thread.I have attached new readings in my previous post(viewtopic.php?f=1&t=5491).I had connected the transistor and pot wrongly.Please let me know if the readings are correct.
Thanks a lot for helping me out.
shubham123
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS
$199.95
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureJohnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A
$1900.00
Johnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A pictureJohnson Controls Metasys Controller CVM03050 Module Board
$138.75
Johnson Controls Metasys Controller CVM03050 Module Board picture
