FETS?
FETS?
Postby rmjr » Wed Nov 21, 2012 2:57 am
There is a mosfet called "Depletion/Enhancement Mosfet" which can be used in two modes either depletion or enhancement.
However there is another type of mosfet called "Enhancement mosfet" which is the one I am looking for and shown at 12:30 of the following video:
http://www.youtube.com/watch?v=NSD7n...hannel&list=UL
This type of mosfet simply accepts positive threshold voltage at the gate which allows an N-channel to be formed by minority carriers connecting the drain to the source. The higher the gate voltage above the Voltage threshold, the more minority carriers form creating a bigger N channel thus allowing more current through drain/source. Is this exactly what the 2N7000 part does?
thank you so must for your help !
rmjr
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink
$26.97
ZP500A/300A/50A/30A 1600V Power Stud Rectifier Diode Negative Reverse/ Heat Sink picture
