Is converting voltage to freq like creating a tone?
Postby sciguy77 » Sat Dec 15, 2012 10:18 pm
Hi everyone,
I'm trying to record analog values with a digital recorder. Basically I have a recorder and have 2 leads connected via the mic port. If I just apply regular voltage to the leads the recorder doesn't recognize the external mic and records with the internal mic. It seems as though the recorder will only read values through the external mic if there is a tone going through it. I know the Arduino can generate tones, but if possible I'd like to do this with a simple voltage to frequency converter IC like the Texas Instruments LM231 (http://www.ti.com/lit/ds/symlink/lm231.pdf). My question is: if I convert voltage to frequency, is that the *same* thing as generating a tone (will it be readable)?
Thanks!
sciguy77
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt pictureGENUINE MURPHY AMMETER AMP GAUGE 60-0-60 65700259 HOTROD DUNE BUGGY
$45.00
GENUINE MURPHY AMMETER AMP GAUGE 60-0-60 65700259 HOTROD DUNE BUGGY pictureFCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES
$16.99
FCI DC Amperes Analog Panel Meter Ammeter Gauge Model/MPN D.C. AMPERES pictureLot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter
$79.00
Lot of 8 Analog Panel Meters Yokogawa Jewell MeterMaster Voltmeter Ammeter picture
