Connect 3 different elements to solar powered battery
Postby mitjaj » Wed Dec 26, 2012 6:21 pm
I wish to connect 3 different elements to solar powered battery.
Battery: 5 V
Element 1: 5 V
Element 2: 4,5 V
Element 3: 3 V
Do I have to connect 2 DC/DC elements like on this scheme:
[img]http://www.electro-tech-online.com/attachments/electronic-projects-design-ideas-reviews/69383d1356545245-connect-3-different-elements-solar-powered-battery-img.jpg[/img]
Or is there a better way to connect this?
mitjaj
Re: Connect 3 different elements to solar powered battery
Postby mitjaj » Thu Dec 27, 2012 8:15 am
Googling this problem, I found out that it would be better to use resistor voltage divider or to use diodes (diode voltage drop).
Somebody suggested this:
5V Battery → Element 1: 5 V
5V Battery → 1N5818 → Element 2: 4,5 V
5V Battery → 1N4001 Diodes x 3 → Element 3: 3 V
Do you think this would be ok?
mitjaj
(12) BRAND NEW SIEMENS Q120 CIRCUIT BREAKER, 120/240-VOLT, 1-POLE, 20-AMP,
$65.00
(12) BRAND NEW SIEMENS Q120 CIRCUIT BREAKER, 120/240-VOLT, 1-POLE, 20-AMP, pictureSiemens Simovert Masterdrive 6SE7015-0EP50-Z USED
$888.33
Siemens Simovert Masterdrive   6SE7015-0EP50-Z USED pictureSiemens Simodrive LT-Modul 6SN1124-1AB00-0AA1
$275.00
Siemens Simodrive LT-Modul 6SN1124-1AB00-0AA1 picture1PC New YASKAWA SGDV-5R5A01A Servo Driver
$214.00
1PC New YASKAWA SGDV-5R5A01A Servo Driver picture
