9v solar cell LEDs
9v solar cell LEDs
Postby akramer08 » Thu Dec 27, 2012 8:56 pm
I am starting a project and need help with the circuit designs as I am new to them. I want 18 LEDs powered by a 9v rechargeable battery. I also want to recharge the 9v with solar cells. The LEDs will only be on for about 1 minute a few times a day. Any suggestions?
The LEDs are 4.8mm(i guess 5mm) straw-hats, 3.0-3.2 forward voltage
akramer08
Re: 9v solar cell LEDs
Postby JoshMac » Sun Dec 30, 2012 2:14 am
Hi Akramer,
What kind of LED are they? I only ask because if they are infrared, they have an extremely high current consumption over standard red, blue, green, white LED's. Just keep in mind that a 9v rechargable, is not 9v, but 8.4v. (AA, AAA, C and D are 1.2v not 1.5). Another important thing to understand is that standard LED's have a 0.7v forward voltage drop across them, so the voltage will drop by 0.7 when they are on.
Assuming they are normal colour LED's there is a couple of ways to wire them up.
The easiest way would be to could run multiple LED's in series (daisy chained), then put those multiple series circuits in parallel with each other.
Each series circuit you would run 3 x LED's in series along with a resistor. To calculate the resistor needed use the formula "R = Vs - Vfd / I".
R = Is the resistor needed.
Vs = Is the Voltage source, in your case 8.4v.
Vfd = I is the foward voltage drop of the LED(s).
I = Is the current (amps) the LEDs will draw (being in this case your LED's would be in series, you add the [u]voltage [/u]together to get the total, [u]not[/u] the current).
So appling that would look like
R = Vs - Vfd / I
R = 8.4v - (3 * 0.7v) / 0.020
R = 8.4 - 2.1 / 0.020
R = 6.3 / 0.020
R = 315 ohms.
A 315 ohm resistor does not exist in the standard 48 range of resistors, but you can just go to the next highest, 330 ohms.
Make 6 sets of those, and put them all in parallel, and you have your 18 LED's awaiting your rechargable battery.
I am out of time for now, Ill try to get back soon to help with the solar panel charging, unless pepe gets in first :)
Hope this helps,
Josh
JoshMac
Postby akramer08 » Thu Jan 03, 2013 10:08 pm
They are white LEDs. If I did a parallel with 6 sets of 3 LED series would I need resistors?
akramer08
Postby JoshMac » Fri Jan 04, 2013 11:52 am
No that will not work, as the power consumption of the LED's would exceed 9v (2.8v per LED (after voltage drop) x 6 = 16.8v). The LED's may come on, but they will be very VERY dim.
Your best option is wire them up as I have mentioned.
A) 6 sets of 3 Series circuits with an LED in each series set.
B) 18 LEDs with 1 resistor per LED.
C) 18 LEDs in parallel with 1 resistor at the end (would be around 470ohm), but thats a pain to wire up, and you will find some will be brighter than others.
go with option A, aka the one I mentioned before.
JoshMac
Postby akramer08 » Wed Jan 09, 2013 5:01 pm
Sounds like a plan. I just got all the parts in and I will do a test run.
akramer08
Postby JoshMac » Tue Jan 22, 2013 1:25 pm
Great, let us know how it all goes.
JoshMac
Nordic Semiconductor nRF5340 DK Dev Kit ARM USB Flash 512KB RAM PCA10095
Nordic Semiconductor nRF5340 DK Dev Kit ARM USB Flash 512KB RAM PCA10095 pictureDCA55 Version Semiconductor Tester, Compatible with DCA55 Semiconductor Analyzer
$88.88
$180.00
$300.00
