HOW TO BLOCK STEADY 12 V BUT PASS PULSING 12 V SIGNAL ?
Postby lod 77 » Sat Jan 05, 2013 3:26 pm
Is there any device that I can assemble that will block steady 12 v signal but let pulsing 12 volt pass thru ?
I have one wire that feeds a light that is either steady 12 volt ( brake light ) or pulsing 12 ( turn signal ) I want a device a circuit that will BLOCK steady 12 volt signal 100 % of the time( brake light ) and let PASS pulsing12 v signal ( turn signal )
Thank you
Larry
lod 77
Re: HOW TO BLOCK STEADY 12 V BUT PASS PULSING 12 V SIGNAL ?
Postby apvkt » Sat Jan 19, 2013 11:27 am
I don't have any idea regarding this.....If i get some information surely i'll share you................Thanks.......
apvkt
Postby JoshMac » Tue Jan 22, 2013 12:58 pm
We might be able to give some more ideas if you elaborated on your problem a little more to give us a clear idea on the problem at hand.
Maybe sketch a diagram in paint.
Josh
JoshMac
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA pictureScintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM
$49.00
Scintillator Crystal CsI(Tl) 10x10x10 mm for DIY gamma spectroscopy with SiPM pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera picture
