Power Factor
Power Factor
Postby 73polarbear » Sun Jan 06, 2013 10:42 pm
If a coil with a .2 lagging power factor is connected in series with 300 watt incandescent lamp to supply that lamp with 120 volts from a 208 volt, 60 Hz power supply, what is the voltage across the coil terminals? Can anyone point me in the right direction?
73polarbear
Re: Power Factor
Postby moki » Sat Jan 26, 2013 5:22 pm
Not that simple. You will have to calculate the inductive reactance (XL). To do this you must know the inductance (L) of the coil. XL = 2 x pi x f x L. So for example the inductance of your coil is 100 milli henry, XL will be 2 x 3.14 x 60 x .1. That will give XL as 37.68 ohm. You will then have to calculate the volt drop across the coil using ohms law v = I x R. So you must know what current the lamp draws as well. Some circuits use a capacitor to drop voltage. A typical example is some daylight sensing switches. Its fine as long as the current is not too high. The formula is then Xc (Capacitive reactance) = 1 divided 2 x pi x f x C. Capacitance is in farads.
Hope this helps or gives you a start!!
moki
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS
$199.95
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureJohnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A
$1900.00
Johnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A pictureJohnson Controls Metasys Controller CVM03050 Module Board
$138.75
Johnson Controls Metasys Controller CVM03050 Module Board picture
