which input is first
Postby sunilsuta » Mon Jan 21, 2013 3:58 pm
I have 2 digital inputs.I want to which input is high first.
Let the two inputs be A and B,
If A goes high first then B,I've to get output as high.if B is high first output should be low.can anyone tell me how to implement this logic using simple gates and flip flops?
sunilsuta
Re: which input is first
Postby JoshMac » Tue Jan 22, 2013 1:01 pm
Interesting,
I dont think you would need flip flops in this problem, perhaps with inputs running through individual NAND gates, and then have the output of the NAND gate removing 5v from the 2nd input of the opposite NAND gate. basically to disconnect other input.
Just a line of thought.
JoshMac
Postby sunilsuta » Wed Jan 23, 2013 10:05 am
@joshmac :thank you very much for your reply.
sunilsuta
Postby MrTechnology » Sat Jan 26, 2013 3:46 am
How long should the output be high for (if A was first)..?
Just until the next A or B high?
MrTechnology
Postby sunilsuta » Sat Jan 26, 2013 9:06 am
@mrtechnology:yes!
sunilsuta
$16.79
EEPROM BIOS USB Programmer CH341A + SOIC8 Clip + 1.8V Adapter + SOIC8 Ad Hot pictureDigilent Basys 3 Artix-7 FPGA Dev Board XC7A35T USB-JTAG VGA Pmod
$120.00
Digilent Basys 3 Artix-7 FPGA Dev Board XC7A35T USB-JTAG VGA Pmod pictureREVELPROG-IS SERIAL FLASH & EEPROM PROGRAMMER (1.8V - 5V + ISP, USB)
$161.00
REVELPROG-IS SERIAL FLASH & EEPROM PROGRAMMER (1.8V - 5V + ISP, USB) pictureSAMSUNG SPW2plus PROM/OTP/MTP PROGRAMMER C & H Technology* MISSING PARTS*
$170.00
SAMSUNG SPW2plus PROM/OTP/MTP PROGRAMMER C & H Technology* MISSING PARTS* picture
