What's wrong with the digital logic design?
Postby adamwth » Wed Jan 23, 2013 6:14 am
Could only upload a picture.
The objective of the design is to make a 3-bit counter that skips counting 4 and 7. So essentially, 0,1,2,3,5,6, repeat.
The one on the left works but the one on the right doesn't. What's wrong with the one on the right?
Thanks in advance.
DIGLG Challenge 3 Pic.png (158.16 KiB) Viewed 4708 times
adamwth
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureNew Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display
$123.99
New Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
