voltage shift
voltage shift
Postby e_gns » Thu Jan 24, 2013 7:24 pm
Hello.
I am not very experienced, so I came here with a request for help.
I have a sensor which gives output voltage from 0V to 5V. The sensor supply voltage is 5V.
What I need is to shift this voltage on level from -2,5V to 2,5V and then amplify it with a gain of 2.
So the adjusted voltage would be from -5V to 5V.
I assume to use some op amp, but which one? There are many op amps on the market and since I am new to this, I do not understand all the parameters and all the types. I have found some rail to rail op amps which are powered by single 5V. Is it possible to use these to achieve my goal or these op amps can not work with negative voltage?
The whole device will be powered from 7,2V battery. So how to effectively achieve my goal?
Could you please post me some specific op amp (circuit) or something?
I appreciate all the help! I am sorry for my English.
e_gns
Re: voltage shift
Postby pebe » Sat Jan 26, 2013 4:58 pm
You will need to feed the negative supply of the opamp from a negative voltage of at least -5V. Have you got a suitable supply?
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V
$11.95
4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V pictureMDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black
$48.68
MDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black picture
