OVER VOLTAGE PROTECTION
Postby moki » Fri Jan 25, 2013 9:28 am
What is the best way to protect circuits from over voltage. I recently had a case where a 5 volt dc switching power supply failed and went up to 9 volt dc. This fried the circuit boards that it supplied. MOVs might be a bit slow , I think. Any ideas, circuits etc will be appreciated.
moki
Re: OVER VOLTAGE PROTECTION
Postby pebe » Sun Jan 27, 2013 11:07 am
A simple way would be to use an SCR crowbar circuit, provided your power supply has some form of current limiting or short circuit protection.
Postby sunilsuta » Wed Jan 30, 2013 2:30 pm
@pebe: I'm not experienced as you pebe.but I have a doubt why can't we use zener as voltage regulator in this case?is it because of SMPS dc is used here?
sunilsuta
Postby pebe » Thu Jan 31, 2013 10:47 am
If a power supply has suddenly increased its output voltage, it must be because its internal voltage regulator has failed in some way. That probably means that its full current capability is now available at its output. If that current is a few tens of milliamps then you could possibly use a zener for protection.
But a 5V SMPS can probably deliver a maximum output of an amp or more. For a zener to give protection it would then have to rated for at least 5W, and for sustained protection would need a heat sink. So the protection would be physically larger than the SMPS, so making a bulky power supply.
If an SCR is used, then once turned on its voltage is quite low and would cause the supply fuse to blow.
Postby sunilsuta » Thu Jan 31, 2013 11:09 am
Oh thank you very much pebe
sunilsuta
Samsung CA4-10M Ultrasound Probe
$550.00
Samsung CA4-10M Ultrasound Probe pictureSamsung AM018ANMDCH VRF Indoor Unit Ducted 18,000 BTU - NEW
$850.00
Samsung AM018ANMDCH VRF Indoor Unit Ducted 18,000 BTU - NEW pictureSAMSUNG CA1-7A CURVED ARRAY ULTRASOUND TRANSDUCER PROBE 30 DAYS WARRANTY TESTED
$1600.00
SAMSUNG CA1-7A CURVED ARRAY ULTRASOUND TRANSDUCER PROBE 30 DAYS WARRANTY TESTED pictureSamsung AM007ANMDCH VRF Slim Ducted Indoor Unit 7,000 BTU - NEW
$775.00
Samsung AM007ANMDCH VRF Slim Ducted Indoor Unit 7,000 BTU - NEW picture
