Can I do this?
Can I do this?
Postby sunilsuta » Sat Jan 26, 2013 3:08 pm
Can I use 8038 IC as a FM radio transmitter(88 to 104MHz)?
Because I saw that the operating freq of that IC is in some KHz.
And I got this idea because we have done this experiment to generate FM in our lab .but I don't know how to increase its freq to Radio freq range.
sunilsuta
Re: Can I do this?
Postby pebe » Sat Jan 26, 2013 4:00 pm
sunilsuta, you should have posted this in the 'components' section.
If you mean the ICL8038, then no, it will not operate up to the FM radio band. Its specification clearly states that its maximum frequency is 300kHz.
Re: Can I do this?
Postby sunilsuta » Sat Jan 26, 2013 4:24 pm
@pebe:sorry for posting at wrong place.
And regarding my question.
If I use that ic to generate FM signal,later on freq up conversion will I get RF FM signal?
sunilsuta
Re: Can I do this?
Postby pebe » Sat Jan 26, 2013 4:39 pm
No. It's a sine/square/triangular signal generator. It cannot produce a modulated signal - either AM or FM.
Re: Can I do this?
Postby sunilsuta » Sat Jan 26, 2013 5:20 pm
@pebe:thank you very much:)
sunilsuta
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable pictureThermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete
$113.33
Thermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete pictureThermocouple Thermometer Digital Data Logger Thermometer 4 Channel K/J/T Type Th
$115.06
Thermocouple Thermometer Digital Data Logger Thermometer 4 Channel K/J/T Type Th pictureThermocouple Thermometer Temperature Data Logger 4-Channel K/J/T Type Thermomete
$109.71
