Circuit using a 555 timer for homework!!
Postby ITT » Tue Feb 12, 2013 4:58 am
[quote]Using a 555 timer create 5khz circuit with a duty cycle of 50%?[/quote] I've been reading my analog circuit book for day figuring this out. I'm new here hoping i can get some help in understanding this simple circuit.
ITT
Re: Circuit using a 555 timer for homework!!
Postby pebe » Tue Feb 12, 2013 6:27 am
There is no point in trying to re-invent the wheel.
Google for '555 timer tutorial' and it will come up with dozens of explanations.
Postby SierraCat » Wed May 08, 2013 2:23 pm
Cleveland Institute of Electronics posted their online lecture notes on 555 timers:
http://cie-wc.edu/555-timer-basics.pdf
SierraCat
Leviton 20A Single-Pole Switch Model #1221 (Lot of 1 - Leftover Stock)
$12.00
Leviton 20A Single-Pole Switch Model #1221 (Lot of 1 - Leftover Stock) pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA picture200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch
$104.99
200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch pictureSensor Switch NPP20 PL nLight Plenum Plug-Load Control 120V, 20A
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A picture
