led controller
led controller
Postby sheldons » Mon Feb 18, 2013 8:48 pm
here are some pictures and schematics for my latest led controller
[attachment=3]
sheldons
Re: led controller
Postby sachinelectrostar » Fri Sep 27, 2013 10:23 am
Hello friend i am unable to see your's picture clearly..
sachinelectrostar
Re: led controller
Postby sachinelectrostar » Fri Oct 04, 2013 9:08 am
Good images thank you for sharing
sachinelectrostar
Re: led controller
Postby PCB-Michael » Tue Oct 15, 2013 6:59 am
it seems great, it's should be mainboard and also you should have one drving board, it can drive some light boards.
Michael
PCB-Michael
Re: led controller
Postby debmitr » Fri Feb 13, 2015 5:50 am
Great though the driving board is missing.
debmitr
$24.99
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureBergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O
$159.00
Bergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O pictureDETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set
$62.99
DETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set picture
