3-axis, reversable stepper motor control circuit required.
Postby zappafan » Tue Feb 19, 2013 12:20 am
.... just wondering if anyone can point me in the right direction if you've seen anything like this before. If you go to the following web site:
( [b][color=#0000FF]http://s1358.beta.photobucket.com/user/zappafan1a/library/[/color][/b] ), the animation quite clear as to what I need to do, with the addition that, after the Sun goes down, the unit will go to a "home" position... pointing East at the horizon. I'll use stepper or servo motors.... not sure which, yet. And, the animation is for informational use only.... I'm working on a different but similar project.
As a thought, I long ago saw a circuit where large model rocket builders were able to make sure their rocket kept going straight up, using two light sensors with a physical divider between the two, comparing the light input to both (from the Sun), and using micro servo motors to control the fins. I suppose my project would require 6 sensors. Thanks!
zappafan
Re: 3-axis, reversable stepper motor control circuit require
Postby pebe » Tue Feb 19, 2013 8:23 am
This message came up on screen:
'! There was a problem playing your video
Video not found'.
Postby zappafan » Tue Feb 19, 2013 5:50 pm
[quote="pebe"]This message came up on screen:
Video not found'.[/quote]
I had the same problem, but I finally found the video on you Tube:
h-t-t-p://www.youtube.com/watch?v=qhaQwPiVutg Basically, this is what I want to do, but not for moving something this large
h-t-t-p://www.youtube.com/watch?v=aSyScg9VRa4
h-t-t-p://www.youtube.com/watch?v=JO4LRj6IR0Q
I'm going to do a search for open source circuit availability and see what I come up with.
zappafan
Postby pebe » Tue Feb 19, 2013 8:24 pm
These are 2axis devices. Why do you want 3axis?
Postby zappafan » Tue Feb 19, 2013 9:34 pm
[quote="pebe"]These are 2axis devices. Why do you want 3axis?[/quote]
You are correct, sir.... I've been working on designs for making changes to my home built CNC machine, and I had 3-axis on my mind. ^_^
by the way, I've found loads of info on Solar trackers. When I get this project done (the 555) I'll have some thinking to do. By the way, where you live/work looks mighty nice on Google Earth. Not many places to do fresh water fishing from what I could see, but the ocean is somewhat close.
I'll be busy tonight, but I'll work on the 555 circuit later and let you know what I've been able to do. What do you do for a living, may I ask?
zappafan
Postby pebe » Wed Feb 20, 2013 9:39 pm
I look forward to see more of your project.
(Off topic)
[quote]. By the way, where you live/work looks mighty nice on Google Earth. Not many places to do fresh water fishing from what I could see, but the ocean is somewhat close.[/quote]
Yes, a very pleasant place. Donald Trump has chosen the sand dunes about 6 miles away to create "The most famous Golf Course in the world" - his words, not mine.
[quote].......... What do you do for a living, may I ask?[/quote]
I am retired now. But I was in electronics for almost my entire working life.
$57.99
Adjustable DC 0-30V/60/120V 0-3/5/10A Lab Power Supply Variable Bench Switching pictureEMERSON SOLA SDP 5-5-100T POWER SUPPLY
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY pictureMICRON INDUSTRIES POWER SUPPLY 24VDC / MD20-24-3C
$299.99
MICRON INDUSTRIES POWER SUPPLY 24VDC / MD20-24-3C picturePower-One (Bell Power) Model: MAP55-4003 Power Supply.
Power-One (Bell Power) Model: MAP55-4003 Power Supply. picture
