I need help with a free electron pump circuit.
Postby AbbottCostello » Thu Feb 28, 2013 7:45 pm
I am getting 5 volts and 20 milliamps from my earth battery setup. I need to output the charge to a small rechargeable battery and then power output to a string of 2 volt LED's. The next thing I want to do with the earth battery setup is to power a Wifi router. I can put more earth battery setups in place to increase the volts and amps if needed. Even though the meter is showing 5 volts and 20 milliamps I think there are more free electrons available. I have been looking at Joule thief circuits to pump free electrons. I want to use this to supply low power for lighting and other things in Nicaragua on my mission there. Please assist if you can and if you know of anyone with electronic experience that wants to go with my group then please let me know.
[deleted personal data from post]
AbbottCostello
$49.99
JOHNSON CONTROLS VALVE ACTUATOR  ‎3Nm (27in-lb)  /  VA9203-GGA-2Z pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureNew Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display
$123.99
New Sealed JOHNSON CONTROLS NSB8BHN240-0 Temp Thermostat Humidity Sensor Display pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
