help with simple regulated power supply
Postby greenearth73 » Sat Mar 02, 2013 8:02 pm
hi
i have little knowledge in electronic but i in need to this circuit
[url=http://www.turboimagehost.com/p/15293607/untitled.JPG.html][img]http://s4d3.turboimagehost.com/t/15293607_untitled.JPG[/img][/url]
its simple ups when the power off it still on for 5-7 min the load is about 1.5A (+12 , +9v) .
Q could be tip110 or anything
i need values for Q,C,R1,R2.
thanx
greenearth73
Re: help with simple regulated power supply
Postby greenearth73 » Sun Mar 10, 2013 5:22 pm
:D any help appritiated >>>>>>>>>
greenearth73
Postby pebe » Mon Mar 11, 2013 2:17 pm
If V1 is the main supply and V2 is the backup battery, then how does the circuit work?
In order for the battery to supply power to the 12V and 9V outputs, Q1 must be switched on. But it can only be switched on by V1 via D1 and R1. The battery V2 cannot switch it on because there is no feed from V2 to R1.
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine
$35.70
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureFactory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit
$699.95
Factory Authorized Parts -Carrier 342813-75101 Replacement Coil Kit  picture1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor...
$20.82
1 Pole Air Conditioner Contactor 40 Amp 24VAC Coil Condenser Contactor... picture
