LT1170 Voltage Regulator help
Postby Happycamper » Sat Apr 13, 2013 4:24 pm
Could somebody help me understand how I would use the LT1170? I need to regulate 3v to 15v coming in and have an output of 6v with a maximum of 5 amps (probably closer to 1 or 2 but could be as high as 5).
The data sheet is found here.
http://www.jameco.com/Jameco/Products/P ... 731999.pdf
Thanks!
Happycamper
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture
