broken watch winder
broken watch winder
Postby rbruceiii » Thu Apr 25, 2013 8:38 pm
I have an automatic watch winder that broke. The winder had variable timed phases based on two switches. In the on position, it would run for 15-30 seconds every 1-2 minutes depending on the settings of the switches (4 combinations), or something like that. I was pretty sure that the motor just crapped out. I replaced the motor. Now in the on position, the motor runs continuously, as if there are no timers. I don't think I did anything to the circuit to affect the timers, but I can't be sure. I'm new to these types of things. Any tips on how to troubleshoot from here?
rbruceiii
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureAllen-Bradley 1775-ME8 Memory Module
$984.62
Allen-Bradley 1775-ME8 Memory Module pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10RAM MODULE (COMES WITH WIRING HARDNESS) -
RAM MODULE (COMES WITH WIRING HARDNESS) -  picture
