How to switch a 12v circuit with a 4V pulse generator
Postby Damian666 » Sun Jun 23, 2013 5:43 am
Hello All,
I have a pulse generator (1MHz max) that outputs about 4v and I need to turn on a turn on the power to a 12V circuit (about 1.5A max), I am after the simplest circuit to do the job. I was hoping to use a simple MOS switch - the problem I have is the MOS transistors I am familiar with require about 10V VGS . Any advice would be appreciated!
Damian666
Re: How to switch a 12v circuit with a 4V pulse generator
Postby pebe » Sun Jun 23, 2013 2:38 pm
The gate capacitance of a FET may be a bit high to drive directly with 4V at 1MHz. I would recitify it with a small diode feeding into a 100K and 1nF in parallel. You an then use the resulting DC to drive an NPN transistor to feed Q1.
Postby Damian666 » Sun Jun 23, 2013 6:00 pm
Thanks for the observation, I will certainly do some simulations to look at this. My 1MHz was probably more than required - I anticipate the maximum frequency to be below 100KHz.
Any suggestions for a FET I could use – I need to ensure that the NPN pass transistor switches off.
Damian666
AR Amplifier Research FM2000 2-Channel Isotropic Field Monitor S/N 13391
$1450.00
AR Amplifier Research FM2000 2-Channel Isotropic Field Monitor S/N 13391 pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER picture# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier
$649.00
# BRAND NEW - PASCO Scientific PI-8127 Digital Function Generator / Amplifier pictureUSED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER
$104.99
USED SKAR AUDIO SK-M5001D 500W RMS ULTRA COMPACT CLASS D MONOBLOCK CAR AMPLIFIER picture
