Amplifying Audio Signal from 3.5mm input
Postby arthur106 » Wed Jul 10, 2013 2:52 am
Howdy!
I'm working on a project and want to have an auxiliary input that can power two speakers (each rated for 80W and impedance of 6 Ohms). It doesn't necessarily have to produce 80W of power, but I want it to be significantly louder than it is now without noticeable audio distortion. I am powering my system with the atx power supply from a computer.
How can I build a circuit that will amplify the audio signal from the 3.5mm input jack as much as possible using what I have? I figure that I'll have to buy some kind of op amp??
Is there anything that is relatively cheap (and small) that I can buy online that will do what I want?
I'm only about to be a sophomore mechanical engineering major, so my understanding of circuits is pretty basic.
Thanks in advance!
arthur106
Re: Amplifying Audio Signal from 3.5mm input
Postby JMACgyver » Thu Aug 08, 2013 5:39 pm
Yes, there is a simple component and circuit that will do that for you.
It is the LM386, available almost anywhere, and pretty cheap as well.
Here is a good page with a couple simple circuit diagrams and detailed explanations (but not too technically overwhelming).
[url]http://tinyurl.com/simple-amp[/url]
--Electro--
aka The Other David
JMACgyver
$5.99
$6.47
Cavitron power potentiometer for Gen 131, 132, 136, 137 pictureClarostat RA30 LASB 100 OHM Wirewound Industrial POT
$14.95
