Low output voltage of the PV module
Postby dacan » Fri Aug 16, 2013 4:18 pm
Hello. I have a problem with the solar photovoltaic module. Output voltage of this module is only 2.80V (Vmpp) (open circuit is 3.60V). How can I boost this low voltage to a "normal" stable 12V? Common one chip converters work with voltage 3V and higher. Simple converters with transistors or 555 will have unstable output voltage because of changes of the input voltage.. I am thinking about this circuit http://www.youtube.com/watch?v=cBWuo3AyK5c but with bigger output capacitor, 12V zener diode nad stronger VD1. Module has power 20W and maximum current 7.30A.
Thanks for your help..
dacan
Lot 6 SanRex PD60KB160 Thyristor Diode Module 60A 1600V on Aluminum Heatsink
Lot 6 SanRex PD60KB160 Thyristor Diode Module 60A 1600V on Aluminum Heatsink picture5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA
$118.84
SCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
