Is there a relay for this?
Postby gudde1251 » Fri Sep 20, 2013 10:26 pm
Hello, I am new to this forum. Here is my project.
I have a Reporter Driveway Alarm (PIR motion sensor with a wireless receiver). This receiver has a built in "Normally off" relay that I can access for an additional external device. This relay engages for about 2 seconds.
I have outside downlighting around the perimeter of the house in the soffits. These are controlled by a Smarthome programmable dimmer on/off wall switch. I have this light switch programmed to come on at dusk and remain on, at variable brightness, starting at 80% and gradually decreasing to 50%, then turning off about 4 hours later.
The Objective: When the Driveway Alarm is set off, I would like the soffit lights circuit to be switched off, then a separate circuit feeding the perimeter downlights to turn on (no dimming required) and stay on for about 5 minutes, then turn off and switch back to the original circuit.
This is all on 120 VAC. Any suggestions on how to accomplish this?
http://www.smarthome.com/7317/Reporter- ... tem/p.aspx
http://www.smarthome.com/2477D/SwitchLi ... ite/p.aspx
gudde1251
15A Latching Push Button Switch 12V-24VDC IP67 Waterproof SPST 1NO LED Light Blu
$92.99
15A Latching Push Button Switch 12V-24VDC IP67 Waterproof SPST 1NO LED Light Blu pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA picture200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch
$104.99
200 Amp Transfer Switch, 48000W General-Duty Double-Throw Safety Switch pictureSensor Switch NPP20 PL nLight Plenum Plug-Load Control 120V, 20A
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A picture
