I'm really amateur. Making to flash a 12v led...
Postby monkeyisland3g » Sat Sep 28, 2013 9:57 am
Sorry, I search in the web but mostly I found only 3v and 6v circuits.
Although I'm not scared to solder components, I'm really new in electronics, I'd like to make Flash this 12v-led arrow
[url]http://www.ebay.co.uk/itm/271265853156?var=570181454985&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
when I switch it on.
In the cheapest/smallest way it could be done.
The project is to make a turn-light on my bicycle with this battery type:
[url]http://www.ebay.co.uk/itm/190900045894?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
and this switch controller:
[url]http://www.ebay.co.uk/itm/390628419797?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
. Thanks!!!!!!
Last edited by monkeyisland3g on Sat Sep 28, 2013 1:58 pm, edited 1 time in total.
monkeyisland3g
Re: I'm really amateur. Making to flush a 12v led...
Postby pebe » Sat Sep 28, 2013 11:02 am
Hi, welcome to the forum.
This is probably what you need.
http://www.ebay.co.uk/itm/Flash-Strobe- ... 1c35c70d3c
If not, can you work from a circuit and are you prepared to make up a flasher using an IC?
Postby monkeyisland3g » Sat Sep 28, 2013 11:18 am
Wow! thanks very much Pebe. That is what I want, probably is cheaper than ic separated components.
Last question, do I need two of these controllers to make flash each Led-arrow or can i connect 2 arrows to 1 single controller and make flash the arrows separately? thanks!
monkeyisland3g
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine
$35.70
New Manual Coil Winder NZ-5 Handheld Coil Winding Machine Coil Counting Machine pictureCarrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX*
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$67.44
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureWestinghouse A200MACAC, Motor Control Starter w/ Enclosure, Coil 110/120V
$120.00
Westinghouse A200MACAC, Motor Control Starter w/ Enclosure, Coil 110/120V picture
