(-) battery connected to bicycle frame?
Postby monkeyisland3g » Sat Sep 28, 2013 4:25 pm
I'd like to create a led-light system for my bicycle, composed by front&rear light and turn-lights and a horn. I got the components from motorbike's aftermarket, all of them working with 12V.
The question is if I can connect the negative lead of the battery (RC 11.1V 8C 900MAH LIPO) to the bicycle aluminium frame (as if ground). Is there any inconvenience? any tip or advice? thanks!!
Ps: thanks to the guy who answered about flash strobe this morning, was really useful!!!
monkeyisland3g
Re: (-) battery connected to bicycle frame?
Postby filtech » Mon Sep 30, 2013 10:10 am
Hi, I am sure it will work cant see why not, the old dinamo system that was on bicycles used the frame for the earth.
filtech
Postby I_Daniel » Mon Sep 30, 2013 3:05 pm
When considering the fact that the alternator which runs either on the bicycle wheel or is built-in into the front-wheel hub then you find that the one pole is connected to the frame and the other to the light.
Check the nut that holds the saddle / saddle-pin to the frame. You could use a large enough washer type connector to connect the battery minus onto that bolt. Just make sure it has a good connection.
The "loose" alternator's one connection is usually done through the clamp to the frame/front fork..
Postby monkeyisland3g » Mon Sep 30, 2013 9:51 pm
Many thanks!
monkeyisland3g
E Two Syneron Candela Sublime Sublative Machine, radio frequency
$1750.00
E Two Syneron Candela Sublime Sublative Machine, radio frequency pictureRadio Frequency Gripmeter Pratt Burnerd Gripmeter 1009-07300 R F Gripmeter
$300.00
$498.00
5 in 1 Body Sculpting Machine Professional Salon Spa Radio Frequency For Home picture0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW
$76.87
0.5M-470M Radio Frequency Signal Source Generator Practical Debugging Instr WRWW picture
