Resistor for Transistor Calculator?
Postby SergioQ » Tue Oct 29, 2013 5:07 am
Hello all,
Am new to electronics and playing around is all. I bout an NPN transistor from radioshack, but when I look up any online resistor calculators none of the fields they ask for, are on the data sheet for the transistor.
Am assuming that perhaps they're using different terminolgy, thought I'd reach out for some help.
Also, really just want to use this for a switch to light up an LED or two. Not even sure if it's too much or too little for a 6V battery supply.
Many thanks,
Sergio
TIP120 Darlington Transistor
Power Dissipation 65W
Collector-emitter voltage 60V
Collector-base coltage 60V
Emitter base V 5V
Collector current (cont) 5.0A
Collecor curretn peak 8.0A
Base current 120mA
Unclamped inductove load energy 50mj
SergioQ
Re: Resistor for Transistor Calculator?
Postby pebe » Fri Nov 01, 2013 4:30 pm
Hi Sergio. You have bought a 50A transistor to switch about 15mA to light an LED. You have certainly got a 'sledgehammer to crack a walnut'!
An explanation of what you require would take up a lot of space, so I think you would be better off if you look to a tutorial. The one at this site explains things fairly easily and should provide answers for you. Look under 'Transistors'.
http://www.williamson-labs.com/
Cable Keyence M12 Connector 8 Conductor. Brand New. GS-P8C10
$53.00
Cable Keyence M12 Connector 8 Conductor. Brand New. GS-P8C10 pictureWestward 19Ye37 Weldingcable, Epdm, 2/0Awg, 600V, Red, 25Ft
$224.99
Westward 19Ye37 Weldingcable, Epdm, 2/0Awg, 600V, Red, 25Ft pictureWire 6 AWG Bare Solid Copper Wire 315 ft Spool,
$275.00
Wire 6 AWG Bare Solid Copper Wire 315 ft Spool, pictureCarol 01776.82.01 Welding Cable, Epdm, 2Awg, 600V, Black, 100Ft
$412.99
Carol 01776.82.01 Welding Cable, Epdm, 2Awg, 600V, Black, 100Ft picture
