some help with LM3914
Postby david1234 » Wed Nov 27, 2013 11:01 am
Hello
I want to use the LM3914 in order to do a battery tester
the batter is good for me from 12-10V ,
I have read the datasheet - and didn't understand how I calculate the resistor
I want to connect only 5 LEDs so very led will show me a down by 0.5V.
can you help\guide me?
maybe show me the equation of it?
Thanks ,
david1234
Re: some help with LM3914
Postby colin55 » Sat Feb 22, 2014 11:41 pm
Buy a 12v digital meter with 4 digit display on eBay for $5.00
colin55
$27.04
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil picture1PCS NEW GRFY035F20D20 for Proportional Electromagnet 24V Replacement Valves
$365.99
