LM555 oscillator
LM555 oscillator
Postby renju » Mon Dec 09, 2013 2:02 pm
with a 5v supply, how to attenuate the output of LM555 to 10mV?
renju
Re: LM555 oscillator
Postby I_Daniel » Thu Dec 12, 2013 6:06 am
The easiest way is to use a potentionmeter ( you know a volume control) that is from pin 3 to ground, and set the output voltage to what you require. i.e you are using it as a voltage divider.
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose
$9.22
15Values 750pcs TO92 Transistors Assortment Kit PNP NPN Bipolar, General Purpose picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
Power Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82 pictureTO-92 Assortment NPN PNP DIY kit 15 value 600pcs Transistor
$14.40
TO-92 Assortment NPN PNP DIY kit 15 value 600pcs Transistor  pictureMJ15024 To-3 Silicone Audio Power Output Transistor 10 Pack
$39.99
