Crock Pot Distillation
Postby SpiderCiders » Tue Dec 17, 2013 4:38 pm
I am attempting to convert a crock pot into a small distillation unit for extracting essential oils. As such, I need for the temperature switch to run on unfixed positions so that I can adjust the temperature. Currently the cord connects to a switch which allows for the unit to run one or two heating elements. I would like to run both elements together full time and be able to control the temperature output. The crock pot is a Rival 3350/2 with the following specifications...
180-250 watts
120 V 50-60 hz AC only
If possible I would also like to get a touch more heat out of the unit. It currently goes to about 187 degrees F and I would like to see it reach 200.
My question is, what sort of switch would be appropriate for modifying the unit thusly?
I am not a regular electronics meddler, just on occasion, so please speak newbie to me. :)
SpiderCiders
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture1PC New Rectifier Brake module rectifier ESD138B 110-115 VAC 50-60HZ ESD-138B
$175.56
1PC New Rectifier Brake module rectifier ESD138B 110-115 VAC 50-60HZ ESD-138B picture
