Li-ion Pcb Charger Not Working
Postby johnyradio » Mon Dec 30, 2013 11:18 pm
I'm trying to charge 4 x #18650 4.2V 4.5Ah Li-Ion batteries. Like these:
http://r.ebay.com/zu9OjA
i'm using this charger:
http://r.ebay.com/6hk1Op
This charger does not appear to be working. Surely my own error. When i charge some good 18650's (not full, but have at least 3V charge), i do not see any of the batteries getting charged. After a couple hours, most of the batteries DROPPED a few tenths of a volt.
What am i doing wrong? Is it a mismatch between this board and the ultra fires? Or maybe these are just fake li-ions?
THANKS!
johnyradio
Re: Li-ion Pcb Charger Not Working
Postby johnyradio » Tue Dec 31, 2013 4:17 am
it's the 8254AA
http://www.sii-ic.com/en/semicon/datash ... c/s-8254a/
the hookup diagram shows separate connections for each of 4 batteries.
will post pix soon of my hookups.
johnyradio
Postby pebe » Tue Dec 31, 2013 3:40 pm
What supply voltage are you using? And is that voltage present on pin16 of the IC?
Postby larry80 » Fri Aug 01, 2014 10:25 pm
Actually I am not able find that link but for 4.2 V and 4.5Ah battery your charger must be of sufficient ratings like 5V and of around 4.5Ah and then only it can charge your battery.
[url=http://www.7pcb.ca/pcb-fabrication/]printed circuit board[/url]
larry80
Bulk Lot ~120-200 AMD AM29F010B-90JI 1Mb 5V Flash PLCC-32 Industrial 253g NOS
$250.00
Bulk Lot ~120-200 AMD AM29F010B-90JI 1Mb 5V Flash PLCC-32 Industrial 253g NOS  picture***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureC15 6NZ High Hp Flash Files
C15 6NZ High Hp Flash Files picturePensky Marten Flash Point Apparatus Petroleum testing Closed cup
$277.38
