Superposition in Bridge Circuit
Postby kbwelch17 » Sat Jan 25, 2014 5:48 pm
I'm having trouble using superposition to solve this problem. Isn't the bridge balanced and thus has no voltage across the positive and negative terminals? Also - what would happen if you shorted the positive and negative terminals?
Here's a link to the image:
[img]http://i43.tinypic.com/288mt12.jpg[/img]
kbwelch17
Re: Superposition in Bridge Circuit
Postby pebe » Sat Jan 25, 2014 6:55 pm
You are quite right. The 5mA current generator across the 1K resistor will produce 5V across the resistor. That adds to the battery voltage so you effectively have 10V applied via a 1K resistor to the bridge.
The bridge is balanced (four equal 1K resistors) so there will be no voltage between its + and - terminals, and no current will flow if the two terminals are shorted together.
Postby kbwelch17 » Sat Jan 25, 2014 8:20 pm
I am having trouble understanding why there would be no current between them if they were shorted together. Why would the current prefer 1k ohm resistor as opposed to another?
kbwelch17
Postby pebe » Sun Jan 26, 2014 5:56 am
If there is no voltage difference between the two terminals, then it is logical that no current can flow between them
That's what a 'balanced' bridge means.
GE RIC5-9W-RS 2017 Ultrasound Probe, Transducer Endovaginal for Voluson E/ I
$1799.00
GE RIC5-9W-RS  2017 Ultrasound Probe, Transducer Endovaginal for Voluson E/ I pictureBK MEDICAL TYPE 8870 HIGHFRECUENCY LINEAR ARRAY TRANSDUCER PROBE 18-6 MHZ TESTED
$900.00
BK MEDICAL TYPE 8870 HIGHFRECUENCY LINEAR ARRAY TRANSDUCER PROBE 18-6 MHZ TESTED picturePHILIPS L15-7IO LINEAR ARRAY ULTRASOUND TRANSDUCER PROBE REF: 453561399357
$1100.00
PHILIPS L15-7IO LINEAR ARRAY ULTRASOUND TRANSDUCER PROBE REF: 453561399357 pictureNOS YORK 025 29583 000 TRANSDUCER 0 - 200 PSI B94
$169.99
NOS YORK  025 29583 000  TRANSDUCER 0 - 200 PSI   B94 picture
