Basic Alarm Circuit
Basic Alarm Circuit
Postby Dippel43 » Mon Jan 27, 2014 10:36 pm
I am trying to help a friend build a basic alarm using a diagram he sent me which I believe he found online. It's been awhile since my EE courses in collage but i dusted off the bread board anyway and tried to set it up as shown in the diagram. But something is not correct, it is a simple alarm that is tripped when a ground is broken. Right now, the alarm will go off, but it is supposed to quit after a few moments so as not to drive everyone crazy. I cannot get it to stop unless i reattach the ground. Any ideas? I've attached the schematic to this post.
circuit diagram
Dippel43
Re: Basic Alarm Circuit
Postby pebe » Sun Feb 16, 2014 3:19 pm
It appears that T1 stays switched on. I would suspect C1 is connected the wrong way round, or is leaky..
Postby colin55 » Fri Feb 21, 2014 7:18 pm
Try 1M between base of first transistor and ground
colin55
ASCO RedHat 8320G192 3 Way Normally Open Solenoid Valve 1/4 NPT 120V AC NOS
$149.95
ASCO RedHat 8320G192 3 Way Normally Open Solenoid Valve 1/4 NPT 120V AC NOS pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureASCO 8210G056 Red Hat Solenoid Valve 1-1/2" NPT 24V AC Watertight Coil. NEW
$450.00
ASCO 8210G056 Red Hat Solenoid Valve 1-1/2OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid
$75.00
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid picture
