Quick quesiton about alarm system battery
Postby geryuuu » Fri Feb 28, 2014 5:56 pm
So I built a small simple alarm system, with a couple PUT's and NPN's and a Relay. The schematic recommends a 12v battery be used. But I was wondering if I could just use a simple AC-DC adapter instead of a rechargeable battery. I was trying to think as to why use a battery, Im guessing incase the power goes out , the battery can still power the alarm system. But please let me know what you all recommend :)
geryuuu
Re: Quick quesiton about alarm system battery
Postby Sebi » Fri Mar 07, 2014 3:30 pm
the alarm systems work always with uninterruptible power supply. The simple wall-wart adapters contains only a bridge rectifyer and a capacitor, so the output voltage depend from load and mains voltage.
The minimum requirement a stable supply with 13,8V output, and a small maintenance-free Pb-accu with parallel (puffer) mode.
Sebi
MSA ALTAIR 4XR Gas Detector Monitor - ALTAIR 4XR
$750.00
$600.00
MSA 10106727 ALTAIR 5X Sulfur Dioxide (SO2) XCell Replacement Sensor Kit-2026 pictureMSA Galaxy Test System for Altair 5x Multigas Detector + 2 Cylinder Holders
$300.00
MSA Galaxy Test System for Altair 5x Multigas Detector + 2 Cylinder Holders picture
