Simple NiMh discharger
Postby unclearty » Thu Mar 06, 2014 6:57 pm
I want to be able to discharge a AAA NiMh battery..(individual cell) ..down to .9 volts at approx 150- 200 mah draw.
I was going to simply use a 2.7 ohm resistor with a 1N4001 diode..however, a friend said that this would not be accurate enough due to the diode...that the battery could drop to .7 volts. I'd like to keep this as simple (inexpensive) as possible. I'd ultimately like to make a number of them.
Any ideas as to how to accomplish this?
unclearty
NEC NVM Voicemail Server Tower DFx/W2k 4-Port Card Recovery CD v3.86
$40.00
NEC NVM Voicemail Server Tower DFx/W2k 4-Port Card Recovery CD v3.86 pictureSCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY
$400.00
SCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY pictureSIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP
$600.00
SIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP pictureIXON IXrouter3 IX2410 WiFi Industrial VPN Gateway Router + Antenna NEW
$324.99
IXON IXrouter3 IX2410 WiFi Industrial VPN Gateway Router + Antenna NEW picture
