Relay design help
Relay design help
Postby traviswallen » Fri Mar 07, 2014 4:02 am
I'm designing a audio equalizer with the option to relay switch between a solid state or transformer output path. I'm worried that the relay will cause a audible pop on the output as the relay switches. My thought is to use an additional relay that creates a resistive path to ground a moment before the output relay switches and remains active until the output switch becomes stable. I'm thinking for one second. Does anyone have ideas?
traviswallen
Re: Relay design help
Postby Sebi » Fri Mar 07, 2014 3:08 pm
Hi!
The pop appear when the potential not equal (e.g serial capacitor with floating in- or output). Without schematic no more idea...
Sebi
$14.98
6Pack K Type Mini-Connector Thermocouple Temperature Probe Sensor Cable picture351302170065 Thermocouple Heavy Duty - 72 Inch -
$50.00
351302170065 Thermocouple Heavy Duty - 72 Inch -  pictureCooking Performance Group Thermocouple 351302170058
$45.50
Cooking Performance Group Thermocouple 351302170058 pictureCooperheat Thermocouple Simulator / Indicator Calibrator TM12-0375
$318.75
Cooperheat Thermocouple Simulator / Indicator Calibrator TM12-0375 picture
