How to Build an Electric Circuit Board?
Postby dikshamahi » Fri Mar 21, 2014 6:38 am
Building an electronic circuit board requires great patience and care. Even one poor connection or misplaced component can cause the whole circuit to fail. Double and triple check each connection and make sure to place every component in the right place. You can never be too careful, particularly if this the the first electric circuit board you have built.
dikshamahi
Re: How to Build an Electric Circuit Board?
Postby Ashok » Wed Apr 02, 2014 8:36 am
Once you decided to develop a circuit, first list down the inputs (It may be voltage, current, pulse or anything) then your required output. Make a circuit in paper with dummy value, then select the correct component value based on calculation, simulate it in software like Pspice, Multisim, etc., once you are satisfied with the output make a breadboard connection,don't be in an hurry, slowly step by step, section by section and verify the output at each section, then connect each section to make it complete, check of the outputs, if you are satisfied with the output go for PCB board using PCB software like cadence, kicad, Eagle,etc.,
All the best
Ashok
Postby miro » Sat Apr 05, 2014 1:58 am
Amen brother - I certainly used those rules when I was making the circuit board for the tachometer.
miro
miro
Bunn 27850.0209 Commercial Server 1.5 Gal 24V DC - USED
Bunn 27850.0209 Commercial Server 1.5 Gal 24V DC  - USED pictureSCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY
$400.00
SCHNEIDER ELECTRIC PAS600PWD PoE ECOSTRUXURE PANEL SERVER GATEWAY pictureSIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP
$600.00
SIM Bank 32 SIM Card Slots Ethernet SIM Server for GoIP pictureBitmain crypto mining server Switching Power Supply (amazing specs for your PC)
$35.00
Bitmain crypto mining server Switching Power Supply (amazing specs for your PC) picture
